TurdFergueson2
Team D.O.A.
I usually monitor my voltage off my 800PRS because my car does not have a meter that shows you your battery voltage. If it does I never saw it. Anyways, I've noticed that my voltage appears mid low 13s all the time. Originally I had a red top up front and an HC800 in the rear, 250 amp alt. Off the radio the voltage was 14.2-4 driving, maybe 13.7 at the lowest. Winter came, and it froze both my batteries I guess. I got the red top changed out in the front to a brand new one and the rear is a new Yellow top. Before that though, I noticed my voltage was staying low mid 13s constantly. So I just dealt with that through the winter as I have another car to drive without those issues.
It got a little warmer here so I started trying to see what's going on. I changed the belt before I changed the batteries. Still the same. I tested everything with a DMM yesterday and today. I put the yellow top up front and a SPV70 in the rear. 13.7 then dips to low 13s. Batteries were at 12.45 with nothing on. with the car running they go up to 13.5 the alternator running showed a voltage of 14.45 and it was driven like 30 minutes prior. I can play my system as loud as I want and the voltage may dip to 12.9 and go back up. I saw what I wouldn't even consider bad dimming, but again it was as loud as I will ever play it. So I don't want to ignore it and be stranded one day. I just want to make sure that everything is ok. I have pretty much changed everything but the alt. I have my old one still, but it's a pain to put the new one back on. So right now I can only say that the issue could be in the wires or the alt. I got no issue rewiring the car if that fixes the issue. I just don't know if the issue is an issue.
Cliffs: Old electrical system always read 14.2+ until winter. Won't go in the 14s despite new batteries.
No changes to the equipment (XA4000, AQ2200D, HDC3-15, all wiring and big 3 done in 1/0 Kicker wire)
Any help with this would be appreciated.
