southstylestang
crazy white boy
well i got bored and tired of seeing everybody on this site building nice boxs so i figured id try to build one myself. i know it sucks but its my first box. i was using a truck box but it had alot of leaks and sounded like shit, so i decided to build a 2 cubic ft box for my infinity 12 tuned to 32hz. box turned out way better then i had thought. i didnt feel like buying mdf b/c i dont plan on keeping the box or the sub or the car that its in so i used some 1/2 in particle bored just to work on my cuts and assembly. i know the cuts would have been a lil better using a new sheet of mdf and the screws wouldnt have been so close to the edge on the 1/2 in. wood but what the hell i had the wood left over from a roofing job, and didnt have a truck to go get mdf so i used what i had. the cuts were pretty good and accurate but after i cut out all the pieces i realized the front piece was warped and when i cut it, it ended up being a 1/4 inch off. //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif but since i was going to be cutting the hole for the sub i figured i could get it to straighten out when putting the box together and it worked. the box is airtight on all the corners except for the top. the top leaks in the corners b/c i havnt sealed it up yet but it doesnt really bother me right now. it sounds WAY better then the truck box i used which was really small. anyways heres the pics. dont really care if you flame or anything. ive seen worse on this site. lol
also this box was hell getting into the trunk of my car. i had to remove the spare and then to turn the box to the front i had to remove the backseat and bend the seat mount to spin the box around. but it sounds great. ill build a new one with mdf when i get my 3000gt if i can decide on what subs to use.
