Jeffdachef
Gunz That Turn on Nunz
[quote name='LongThrow']D
And @Jeffdachef, about what you said about Hifonics, look here
Hifonics are now CEA 2006 Compliant.[/QUOTE]
It doesnt matter, I had two brx 2400s on my 18s which are CEA compliant hifonics and compared it with a DC audio 3.5 which is not CEA compliant and my DC audio amp completely mopped the floor with those amps. CEA tests mean jack sh*t since it only tests power at 4 ohms. Not 2 ohms or 1 ohm, just 4 ohms, They also dont even test for efficiency or damping factor either. Amp can be utter junk with 1 ohm performance with a CEA stick slapped on it and people will buy it unknowingly. Its better to look at dyno tests along clamp tests with oscilloscope or actually hear amps perform real life rather than buying something labeled CEA. Only time that would moderately work is with noobs buying 4 channel amps. Even then, its not guaranteed the amp's sound would be good, it might be loud but SQ might be bad.
Not all hifonics are built the same. The zues and HFI lines are amongst their worst of the their worst vs their brutus lines which are acceptable budget amps. Buddy on facebook clamped a zues 3000 and got 1400 dirty watts out if it at 14.4 volts wired to .5 ohms rising to 1.2
