Atlanta007
Starting a new install and planning to replace the stock battery terminals with aftermarket for solid connections and a cleaner look. I attached photos of the stock + and - terminals. It appears these stock battery cables have a cap on them and then are essentially soldered to the side of the terminal ring. Or maybe the ring is made with the cap on it and the wires are just soldered into it. Are these common type terminals?
I'm not sure if this is welding cable or what, but the strands are pretty thick and it's going to take some time and effort to cut through them. They are not very flexible. I will probably just replace the negative cable with some 1/0 kicker ground wire as it is a short run. But since the battery is in the trunk I really don't want to mess with replacing the positive cable and run it all the way to the front.
I just wanted to ask anyone that might be familiar with this type of stock wire/terminals if there will be any issue with attaching the positive cable to a battery terminal that uses a set screw rather that soldering it or some other method.
hope the question makes sense; thanks.
My plan would be to use a stinger dual 1/0 negative terminal and I have a dual 1/0 phoenix gold positive terminal with one side fused.
