Noob question sorry....
I had an APSM1300, as long as u set ure gains with a DMM for that amps rated power or less and ure not going past that volume max you set it to. Ure not clipping, but u could try turning ure gain down a lil and see if it gets clearer
idk what my volts r alt my volt meter is in the mail right now. i have both those amps hooked up. and i have a 80a stock at. and those amps would pull 150a but if the cadence is only pulling 110w its prbly closer to 111a... i don't remember what my gains are set at.
This is what u do leave system alone till ur meter arrives. Make sure to pull ur reading from the amps terminals... Go buy a DMM and set ur gains correctly.. Other option is to keep doing what your doing till your amp releases that sweet smoke. I can only imagine that AP amps dont do well with low voltage..
This ^^^^ but if u have 2v preouts then ure gain shouldnt be higher then 2-3oclock, setting it there dosnt mean u wont clip but its a visual idea of about where 2v is on the gain. If your preouts at 2.5-3v's it prob needs to be closer to 12-1oclock
^^^ U ever priced a HO alt??? Lots of people dont have $500 laying around. That being said with the amount of power he is running a HO alt is not really needed. A second batt or if you have not replaced ur current batt with a nice sized one then thats what I would be doing.
There is a thread on here showing u how I will try and find it but I mean u need a DMM first. Kinda suprised you dnt already have one.
Mr.meyhem
Mr.meyhem
Cold as F***, MN
Mr.meyhem
