Noob problems
Woopy woop
Ga
I’ve got two Power Akoustic Gothic GW 124s and a Rockville RXD-M2 Amp, I’m quite new to car audio, would these subs and amp work? What gauge wire should I run for power, ground and inside the box to the subs? I’m asking stupidly after setting the subs up because I’ve hit some bumps in the road I had them in my truck for a while and they were perfectly fine but I had to take them out because of damage and I’ve recently decided to reinstall them, And now if I turn the bass and volume up to much they cut out and go into protect mode? Long post, sorry, any details about the vehicle, subs, amp, wiring, or the damages, I can answer.
yah, theyll work. doubt subs will do 1200 watts RMS each. maybe 200-300 lol
for power and ground, i use the biggest wire the amp terminals fit. for subs, id use 12 gauge
you can get speaker wire cheap at https://www.monoprice.com/
heres the gain setting info. the test tones are at the very bottom
good info for newbs...
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
Thanks! It may never have made it to U.S. retail. Actually, I highly doubt it! They have diversified their product line now as can be seen on...
Woopy woop
Woopy woop
Ga
Glen Livet
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
