Noise on sa8 v3 sundown free air
It's probably normal noise, just about every high excursion woofer I've played around with free air has a lot of suspension/air venting noise. Its normal and is no longer audible when mounted in an enclosure. This includes some of the older SA8's.
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
Yes i know that's what i was planning on. Unfortunately the rvca's are a little difficult to gain access to. My other thought was to wrap a wire...
Herreraxto
Herreraxto
Texas
Massive spl
    May 18, 2024
    May 18, 2024
