No speaker Specs, how do you determine enclosure requirements?
Joseph7195
Walkin Tall
I have this small 6 1/2" sub that was used in a home theater, that was given to me, and I have no specs on it whatsoever.
I want to use it in a sub reinforcement in my home theater too, but I have looked everywhere online and cannot find any information on it.
It's a nice sub, built very solid, and has the perfect power rating and impedance for my current home theater receiver. 175 watts and 4 ohm impedance.
Is there a way to determine a good enclosure, or is an enclosure impossible without specs?
Could turn out to be fun... Hell you know you will learn even more then u already know so its time well spent...
Yep, I guess you're right. Plus I can use all the small scraps of wood I have been collecting over the years of building big enclosures. I will probably start off building a couple small sealed boxes.
Any good starting points on sealed enclosure size? I was thinking of .5 cubes and go up from there.
Yep, I am trying to think of a good way to waste the least amount of wood, but still be able to find out the proper box. Here is a couple of pics for anybody that might recognize what this sub needs:
This is a shirt I won in a contest with DC Creations!! Thanks @pro\-rabbit ; !!
If anybody finds any info, please let me know, I will probably try to get an enclosure built tomorrow sometime. I will post up all the info I used (as always,lol) that way I might be able to help somebody with my trial and error too!!
I have thought about doing it this way:
Just make a rectangular cube (y-axis a lot longer) and just remove the back panel and trim all the sides down an inch or two at a time and just screw the rear panel back on. Only problem i can see with this, is it will waste a lot of wood.
Shirt looks good, glad it went to a good home.
As for the enclosure, I would think something around .3-.6 net should be just fine. Just tune real low for hone theater applications.
287
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
357
488
411
Joseph7195
Walkin Tall
Joseph7195
Saltillo, Mississippi, United States
Joseph7195
    May 24, 2024
