no sound
globalminds_ent
Having a problem I run a bk800.4 and a audiopipe apk3500 both of the amps power on but no sound? The power light on the 800.4 comes on but the three lights at the top are not coming on. Sometimes it will randomly pop on if I hit a bump something has to be loose I checked all the wires don't know what it could be
Any help thanks
Since *both* amps won't produce sound focus on what is common to both amps:
Power source? Are they both powered from same distro block? If so check battery to block connections - tighten block terminals and batt terminals - replace main feed fuse (even if it looks OK). Similar checks if going to common ground block or point.
Remote turn-on wire.
Signal source? RCAs, or bad HU
What are those three lights that aren't coming on supposed to signify? Audio signal? Lights to highlight the amp's logo? Plug an ipod straight into the amps to make sure they're working properly. If they are, then plug the RCA's going into the amps into your battery powered boombox that has an AUX input to make sure signal is flowing all the way through 'em. If both of those aspects check out, then I don't know what to tell you.
Hitting bumps and intermittently coming on seems like a loose connection somewhere down the line. Your RCA cables could have a broken connection somewhere down the line, but you should check signal everywhere before you go tearing things apart.
globalminds_ent
globalminds_ent
oxford ms
globalminds_ent
BP1Fanatic
BP1Fanatic
