no sound
Ah, I didn't expect you to have an auto-ranging DMM. Most people who buy one just for CA buy the cheapest one they can find. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Okay, so did you h ave the red probe plugged to the right side and the black one in the middle of the DMM? The left red plug is only for DC voltage.
popup_image.php
to save the click
edit: that failed
where exactly should i be putting the sensors from the dmm on the sub?
You can either put them straight on the terminals (+ and - of the terminal, I'm not sure if mach 5 has push-in terminals or screw in, but just wherever you would normally hook the wires to on the sub), or you can put the at the end of the wires you have connected. + and - don't matter when measuring resistance, it'll just differ between whether it gives you a + or - reading on the DMM.
if i put the red lead onto the red screw terminal and put the black one on the wire coming out of that terminal that connects to the cone it gives me a bunch of changing numbers. i have tried to put the red and black leads in every combination and that is the only time a get any reading at all.
yes
Okay, so there is something bad between the tinsel lead and the terminal. Can you see any visible burns or melted parts ont he lead wire or the screw terminal?
Sorry for the delayed response, I was heating up some food. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thank you for walking him thru meter school
i appreciate your help
and he does too
i definitely appreciate everyones help, i feel like an idiot. i have had probably 5 different amp and sub combos and this has never happened...
i have to leave work now and go home
i am offline until Tuesday
i will check thread then
LILJOJO4711 call me if you need me
when a new sub is to be screwed in and wired up please call me so i can walk you threw it
liljojo4711
liljojo4711
dallas
liljojo4711
