no sound
liljojo4711
i was messing with my amp settings yesterday trying to use the dmm and set them correctly. i have a 50hz signal playing, unhooked my sub, connected the leads for the dmm. needless to say im retarded and finally figured out i was adjusting the bass boost instead of the gain (it was dark) and got it adjusted. then i hooked my speaker wires back in but now my sub isnt playing. amp is not in protect, fuses are all good, the subs just arent getting power i guess. i dont know. any help???
like i pmd you
that amp came out of a customers car that was used 6 months
i checked amp prior to shipping to you
you said amp was working 3 days and now it is not working
you said green light is on and amp is not in protect
check your ground on amp
also how many , what kind, what voice coil configuration is your sub stage
i know what he needs to do but i was explaing to him as he is pm'ing me
he said he has power coming out of amp
i told him to check each coil on the sub and see if his mach 5 dvc 2 ohm sub is reading 2 ohms on each coil
is the amp on? did you touch the speaker terminals to a ground? if so, buh bye amp
i feel he should have NOT started to set gains with a dmm if he never used a dmm
he should have
installed everything
turn radio volume to 30 more or less
than put in a cd with a bass song he is familiar with
than gently raise gain from nothing till it starts booming well
if amp has a 0-180 phase, adjust that from 0 than 180 see if you get the sub moving
you said you had sub and amp going for 3 days now nothing
why did'nt you pick up the phone and call me with the 5 business cards i sent you and ask me
liljojo4711
liljojo4711
dallas
liljojo4711
