no sound on aftermarket stereo
so after wiring it all up correctly... their is no sound playing at all!! //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
The stereo turns on and is fully functional but their is absolutely no sound. What could be my issue?
Info:
Stereo: JVC- KW-AV61BT
Harness: PAC C2R-CHYNA
Car: 2005 Chrysler 300C with REF stereo
EDIT:
The harness for my stereo has blue/white and blue wires that are not hooked up. The harness I bought to integrate it, does not have any blue/white or blue wires coming from the harness. Could this be why? what do I connect these too?
There is a few different Harness for the LX models. Make sure you have the right one...
Does it have sound with a CD or USB for Source?
Or just no Radio?
If it had an Amp it would be under the Dash near the Steering wheel..
The Solid Blue wire needs hooked up to a ACC power source. That's your power Ant. Wire. I know yours doesn't have a power Ant.
The Blue and White is your Remote Wire for an Amp... It won't be hooked up unless you installed an amp.
I've ran into this on my own Dodge Charger and Grand Cherokee.
Lube
Lube
United States
Ramrod
