No screws?
yea they do speed up the build, but I still pull and fill before routing the edges if I use them but that's just to make sure the box last no hard edges to chip, but I have also never made boxes for comp use just daily drivers.
if you don't cut your wood very straight, screws do help quite a but. As for me, all glue for the most part.
Thats when you cut a new piece and use a guide bar and some clamps or even screws to hold down the guide if you have too, then fill them later with tightbond and wood dust mix.
You wait until I see that carpenter that built my garage onto my house!!!!......I could have saved some money on fasteners and just glued & clamped it to my house.....LOL............Just kidding guys........I for one am an ole school builder and will always use screws in my enclosures.....
I clamped straight edges to the wood as a guide before every cut. I don't have a lick of carpentry experience. Not even shop class in school. But it just seemed like common sense to do so. Btw, cutting 45's for the first time in my life right now... Not hard except for when I drooped my first cut and dented the 45 degree edge so bad that I had to start over, lol...
If you have no help use a table or saw horse set to catch your drop pieces, keep both hands on the saw pressing over towards the guide and down/forward with steady low pressure.
So I just put my port walls in. I had glued them together using 90 degree clamp, and then after that dried, clamped in the 45 that goes on the corner. Set in the enclosure on the titebond, placed 100 lbs of iron on top to clamp it down.... and then, well after it was too late to fix, measured the port. The back port wall is a hair under 1/8 of an inch over the 4 inches it's supposed to be away from the rear panel. The other, longer, port wall is exactly right. 4 inches. So I have 11 inches of port wall a tad off, and 14 inches that's perfect. I don't think there's any going back, either. How bad is the damage here... anyone know? Other than that, its going well. Just SLOW, lol.
Almost done. Just have to cut out holes in the front baffles and put the top panel on.
The section of the port that's a tiny bit off. My only real mistake so far.
I just don't think your going to experience anything negative from it.
Hope so. Thanks for the feedback in this thread, too.
av83
av83
Midwest
av83
