No in the area has 1" mdf.. Can I glue two sheets of 1/2" together?
What subs are you building the box for? If you are going to run a lot of power, you might end up splitting a panel on the inside and not even know it. Mdf chips in your spider is definitely not what you want.
a 6$ bottle of TB-II and no roller needed just use a scrap of thin poster board and spread the glue out all over then tack it together with a brad nailer to hold ot til the glue is dry
LN will never be as strong as a dedicated wood glue...
tests have been done and proven it more than once...
I used to think LN was better as well.... I was wrong..
No roller is needed but then again neither is a table saw or a router... but they sure do make it easier and more quality of a job.
Buck, great idea. I did that tonight, and it actually didn't wheeze like a fat guy trying to run a marathon. I am going to put two windows that...
19
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
977
dc audio lvl 3 lvl 4 soft parts recone kit they kot hard af at 27 hz
DIYMA is a car audio forum and 1000 times more busier then here. Just ask in the general forum for someone who makes custom pillars. I know a...
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
Vagomire
Vagomire
Rockford, IL
SicAudio
maylar
    Jun 2, 2024
    Jun 1, 2024
