ok guys, i am going to ask your opinion on this one. to this date, i haven't built a set that doesn't sound amazing to my ears. that is except for my 4-per-side NSB setup which would make you rather deaf than forced to listento their atrocious sound. anyway, here is my new setup, and i need some suggestions on what to change, as this will not be cheap //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif . here we are:
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=297-420
2 per side
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=264-524
tweeter
if anyone has BB6, then i can send them the design file. other wise, this'll have to do:
Driver Properties
Type: Standard one-way driver
Company: Hi-Vi Research
No. of Drivers = 2
Mounting = Standard
Wiring = Parallel
Fs = 47 Hz
Qms = 3.4
Vas = 17.2 liters
Xmax = 5.25 mm
Sd = 117 sq.cm
Qes = 0.38
Re = 6.3 ohms
Le = 0.84 mH
Z = 8 ohms
Pe = 120 watts
Box Properties
Name:
Type: Vented Box
Shape: Prism, square (optimum)
Vb = 0.565 cu.ft
Fb = 43.9 Hz
QL = 7
F3 = 53.66 Hz
Fill = normal
No. of Vents = 1
Vent shape = rectangle
Vent ends = one flush
Hv = 0.75 in
Wv = 6.5 in
Lv = 11.85 in
2 per side
tweeter
Driver Properties
No. of Drivers = 2
Mounting = Standard
Wiring = Parallel
Fs = 47 Hz
Qms = 3.4
Vas = 17.2 liters
Xmax = 5.25 mm
Sd = 117 sq.cm
Qes = 0.38
Re = 6.3 ohms
Le = 0.84 mH
Z = 8 ohms
Pe = 120 watts
Box Properties
Name:
Type: Vented Box
Vb = 0.565 cu.ft
Fb = 43.9 Hz
QL = 7
F3 = 53.66 Hz
Fill = normal
No. of Vents = 1
Hv = 0.75 in
Wv = 6.5 in
Lv = 11.85 in
