Newest build, FI inside...................
Pyro_By_Nature
I can't really call this a build log, didn't take many of the actual build.Only got a couple in before the camera died.I can't call this a "look what UPS delivered today" thread either because I didn't take any pics of the sub out of the box.Oh well.Here's some install pics anyway.
While the port had 1 thin layer of paint on it
Painted port piece.Textured paint.
Fi FTW?
It's not pictured, but some bracing was added. 2x4's will work for now.All cuts turned out perfect, table saws ftw!
Termlab results will come tomorrow after I get off work.
Box specs. - 6.5cf. tuned to 31hz, 93sq in. of port area.It's receiving approx. 3500 watts rms.
Single baffle //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Looks great, but you may blow that box to bits //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
After the bracing, I honestly don't think this box is blowing apart //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Guess I need to take a pic of the bracing someday.
did you use a ton of bracing? Or just two 2x4's?
More than 2 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Next box I intend on a double baffle and threaded rod for bracing.This has to hold me over until spring.
If I had the sub rear firing, I probably would've done a double baffle to give the screws a little more bite.But I felt with bracing and the sub facing up, it'd be sufficent.
Pyro_By_Nature
Pyro_By_Nature
Colorado
IgnoreMe
