newbie subwoofer help
I have a Cerwin Vega VMax dual 4 ohm 12" woofer in a slot port box that is being ran by a kenwood KAC-9105D 1800w Max/500w RMS amp all controlled by a kenwood DDX319 DD Headunit. My amp gain is turned to 0 and my H/U settings for the sub are 120hz/120hz. I had it installed at a local shop in my hometown and recently my Vmax started making a loud "pop" noise on certain songs that never used to be a problem. What might cause this, btw my amp is ran in a 4 ohm load so it is only pumping out 500rms. Please help.
how do they have it wired? if they hooked just 1 side of the sub to the amp it is wrong you either run it in a parallel or a series. so take the sub out to see or if you have a multimeter you can check thru the sub terminals on the box and if it reads 4 ohm they just used 1 side and you have to rewire the sub to a 8 ohm which is series or a 2 ohm which is parallel. any reading other then 2 or 8 ohm is wrong and can destroy your sub. If you have any questions feel free to contact me anytime. Hope I gotcha straight but if not someone on here will let me know lol. G/L
check this link out below it will help you out :
Subwoofer Wiring Diagrams, One 4 ohm Dual Voice Coil (DVC) Speaker
http://www.caraudio.com/forums/general-discussion/4511-wiring-only-one-voice-coil.html
Thanks buddy. I've got a sound comp coming up in July in my hometown that im trying to get ready for. This is my first one that I've ever participated in as I am fairly new to the car audio scene. Btw this setup is in an 05 silverado crew cab.
what kind of comp? Idk if that set up will be up to par.
np bruh anything to help out a fello car audio brotha
Its a local SPL, DB Drag event that got so much attention, it is now up on termpros website. Its got local and national classes. Im not going for ranking, i just am curious how much im hitting as is.
05bamfsilverado
05bamfsilverado
Pocatello
05bamfsilverado
