Newbie Question
11
ca
For any sub; Do you have to build the box from the website specs for example, or do you just build it based on experience? For Example: The box you would build for a re,adire,IA,etc would be different then the one you would build for say, a walt mart brand sub.
Never seen this asked, so i must be really noob eh ? //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Thx
hey.. it depends on ur sub type.. are u plannin on building a box..?? each sub sounds better in a certain box..no u dont have to use a website.. u can have someone make ur the measurements for a box.. for free... or a lil bit of money.. or u can have someone build it.. id build u one.. for pretty cheap...
Yo,
So i guess i would have to build all kinds of boxes for a sub to see which sounds best. I would not let you have the fun of building me a box :p....i wanna try
what kind of sub its it. someone could probably tell you right off the bat.
^^ ^^ ^^ I understand this, but I'm asking if for example; A sub just magically fell outtta the sky and I said...Hmmmm....What kind of box would this thing sound good in.
Yes, and there are always nice ppl here ready to help //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Ty all and Merry Christmas //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
T/S (THIELE/SMALL) PARAMETERS: terms used to describe the characteristics of a given driver. The most common T/S parameters encountered are:
Fs = resonance frequency of the driver. In free-air, the driver's impedance will peak at this frequency.
Pe = Thermal capacity of the driver, in Watts. If continuously driven above its rated Pe, the driver may prematurely burn out and fail.
Qes = Electrical Q of the driver at Fs. Qes is a measure of the driver's tendency to resonate at Fs, based on its electrical characteristics, e.g. magnet strength, magnetic circuit characteristics, etc.). The driver's overall resonance characteristics are usually dominated by Qes.
Qms = Mechanical Q of the driver at Fs. Qms is a measure of the driver's tendency to resonate at Fs, based on its mechanical characteristics, e.g. surround compliance, the compliance of the spider, weight of the cone, etc.
Qts = Total Q of the driver at Fs. Qts is a measure of the driver's tendency to resonate at Fs, based on its overall characteristics. Qts can be calculated using the equation: Qts= Qms*Qes/(Qms+Qes))
Re = DC resistance of the driver's voice coil. Re is less than the driver's rated impedance (normally 4 or 8 ohms).
Sd = Effective surface area of the driver. Roughly equal to the area of the cone plus 1/3rd of the surround.
Xmag = [DUMAX] Excursion limit due to the magnetic limitations of the driver's motor. Xmag is defined as the displacement at which the BL product has fallen to 70% of its value at the cone's rest position.
Xmech = Maximum physical excursion capability of the driver. Exceeding Xmech normally results in damage to the driver.
Xsus = [DUMAX] Excursion limit due to the driver's suspension. Xsus is defined as the point at which the compliance of the suspension has decreased to 25% of the value at the cone's rest position.
Xmax = Linear (one-way) travel of the cone. Xmax is used to determine the maximum linear SPL capability of the driver, and can be defined in a number of ways. The DUMAX definition is objectively the best one, and it is defined as the shorter of the Xmag and Xsus values, in each direction of cone travel. This definition is more useful than the older definition of Xmax, which was solely dependent on the length of the voice-coil vs. the length of the gap.
Vas = Equivalent air compliance. The volume of air that has the same compliance ("springiness") as the driver's suspension. Because less air is more "springy" than more air, a large Vas represents a "loose" suspension.
Vd = Peak displacement volume. Vd = Sd*Xmax
^^ ^^ You just tought a man how to fish //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Ty.
Cheers m8 //content.invisioncic.com/y282845/emoticons/toast.gif.bc0657bf54b9ee653b6438524461341e.gif
ca
