Newbie question about power handling
They are very similar stats and both are useful. Often times, thermal power handling is the RMS rating and other times it is not. Thermal power handling is how much power the voice coil can take before burning up. RMS power is how much the sub is able to take before doing damage to the sub/coil. Power handling can be mechanical or thermal as you can blow a sub while not burning the coil and you can fry a voice coil without causing mechanical damage to the sub.
Every RMS rating I've ever seen is thermal power handling. Thermal rating is independent of enclosure. Mechanical power handling is entirely dependent on enclosure. As such it is basically impossible for a manufacturer to provide a mechanical power handling spec without specifying a box along with the rating.
good explanation
MTX actually uses free-air mechanical power handling for their RMS ratings or at least they used to back in the MTX 7000 days.
RMS and thermal power handling specs are set for a reason, of course, so how is it that some subs are able to take more - sometimes MUCH more - than they're rated? it differs across subs, of course, but how does one tell if it's safe -- aside from what you would hear on the forums and such?
I've got a guy in another board claiming that he can send 500 watts to an 8" sub rated at 150 watts RMS "as long as it's clean power." I call bullshit on this dude because we're not talking about AA or SS here - it's MB Quart.
People think putting a sub on an amp rated at 500rms means that the sub is handling that power. This isn't the case as the gains and volume knob control how much power the sub is actually getting.
Some subs are overbuilt in the thermal power handling department but that doesn't mean they need that much power to reach decent output levels. My av12 can take around 1krms thermally but I had it approaching mechanical limits around 400-500rms. I don't need any more power past that but I know that the coil can take it.
understood by me, but that's not what I was really talking about. this isn't about running a sub on a monster amp with the gains down - it's about people saying "yeah that sub is rated at 500w but you can throw 1000w daily no problem."
if a guy says he's going to power a 150wrms sub with 500wrms, he's not talking about turning the gains down to compensate. he's talking about running it at 500wrms -- gains adjusted to that level and at a high enough volume to bump max.
500RMS means that the sub can shed the heat from that amount of power indefinitely without failure. This means a constant sine wave of that power fed to the sub. Music is nowhere near constant and the amp is nowhere near averaging out to that amount of constant output. RMS only matters on test tones. With music, it means nothing.
dan5505
dan5505
Montana
helotaxi
