Ok...so I installed a AVH-P3300BT Pioneer along with a phoenix gold RSD65CS component set. 5.25" rear door infinity reference speakers, and a concept 2 channel amp to power the components.
Now that I have them all in I need some guidance on getting these set before I move to the next install of subwoofer.
amp specs:
I am powering this set of of a Concept 2 channel CC-1252 amp
Here are its specs:
4 Ohm Stereo Power (RMS): 125W X 2
4 Ohm Mono Power (RMS): 400W X 1
2 Ohm Stereo Power (RMS): 200W X 2
Signal-to-noise ratio: 100 dB
Frequency Response: 5 Hz - 50 KHz
Total Harmonic Distortion: 0.05%
Input Sensitivity: 200mV-4V
Length: 11.82"
Width: 11.66"
Height: 2.37"
Continuously variable 0 - 18dB Bass Boost
Built-in continuously variable 18dB per octave crossover, from 50Hz to 250Hz
Platinum Connectors
rear speaker specs:
SPECIFICATIONS
General
Power Handling, RMS 45 watts per channel
Sensitivity 90dB @ 2.83V
Frequency Response 80Hz - 20kHz
Mounting Depth 2-1/8"
and I am sure some of you are familiar with the PG RSD65 components.
I need help getting the power to the compenents that make them "happy" and sound great. I hear they like 100-150 rms. I would like to do 100 if possible.
Crossover that came with the components are mounted on the door, and set to 0db on the switch that has +2 or 0.
I have the components ran to the concept amp with all crossovers turned down on the amp..HPF and LPF. the switch is set to FULL on the amp. gain is barely up any.
Where do I begin. I am pretty sure I have all my settings on the pioneer to flat...unless I missed something. Subwoofer setting is turned off. all other settings are 0 ...loud is off....bass boost is off..HPF is off, etc.
The infinity rear speakers are just running off headunit power. HELP
The HU only turns up to 40...so I am guessing I need to set it at 30? I am not sure what it clips at or if it even does.
amp specs:
Here are its specs:
Length: 11.82"
Width: 11.66"
Height: 2.37"
Platinum Connectors
rear speaker specs:
SPECIFICATIONS
General
