How do i hook up my comps /w crossovers to a 4 channel.
TroubleGSS
its basically in the tite ive searched everywhere. im a total newb btw. point me in the right direction.
or is this correct?
You can either use two of the four and hook each side up to their respective xover or, if your amp is capable, bridge the connections (check your manual) and run each side to the xover.
Which would be better? from a quality pov? i hope i don't blow **** up. i went cheap on the comps got sum 6.5 crunch p1 and 5.25 and 5.25 groundpounder both with tweeters and the amp is crunch p1 600.4. the subs will be SSa Dcon 12" with a MBQuart ONX1.1000 i have a jvc hd r620 hu
Depends on the RMS rating of the comps and the amp. Don't have time to look them up ATM, but try to match as best you can, but keep in mind that your amps shouldn't ever be on MAX: 3/4 up should be your ceiling.
cool, and what test tones should i use for the comps? i only listen to pretty much rap n r & b.
Im assuming i should wire parallel since thats what the site you gave me suggested.
Do i need to hook my tweeters up to my crossovers?
Yes. You hook up one set of mids and tweets to one xover.
and i would wire the 5.25's to one crossover and the 6.5 on another, unlike the pic right?
If I understand correctly, just pretend that you are hooking up speakers when connecting xovers to the amp. From there, you hook up the mids and the tweets to the xover.
TroubleGSS
TroubleGSS
United States
TroubleGSS
