Newbie needs help installing a PAC SWI-Jack in a 07 NBS GMC
SPEEDYGUN
I have a 2007 NBS GMC Sierra, without Bose, and I am installing all of the following:
METRA Ltd 40-CR10 Chrysler Vehicle Antenna Adapter Cable
Metra 95-3305 Impala/Monte Carlo DDIN Dash kit
Kenwood KCA-iP300V iPod Video Direct Cable
Kenwood DDX512 6.1-Inch-Wide In-Dash Monitor with USB/iPod Direct Control/DVD Receiver
SWI-JACK JVC/ALPINE/CLARION/KENWOOD Steering Wheel Control Interface
Sirius SCVDOC1 Sirius Connect Plug & Play Vehicle Dock
can anyone point me to some write-up threads?
I have searched for an hour and can't find anything. If not, can someone help me out with this.
I want to make sure I am hooking the SWI up correctly.
Are these steps correct?
I tap the black ground of the SWI into the black ground wire of the Gmrc-lan-01. I tap the red SWI wire into the red wire of the lan-01 also
I cut the brown loop wire on the SWI
Then I have the green interface wire to hook up. What do I hook it up to and where is it located?
Also, it states that the blue/yellow wire from the SWI goes to the remote input wire from the Kenwood radio harness.
In the Kenwood manual it states
"to use the steering wheel remote control feature, you need an exclusive remote adapter, (not supplied) matches your car is required. When the terminal is not in use, leave cap on)."
The Kenwood wire has some type of connector on it. Can I connect these wires with a normal butt connector or do I have to have a special connector to connect the 2 together?
And lastly, the Kenwood harness has a brown "Mute" wire that is suppose to
"connect to the terminal that is grounded when either the telephones rings or during conversation."
Where does this connect, if at all?
Sorry for all the questions, but again, i am a newbie.
SPEEDYGUN
SPEEDYGUN
Louisiana
SPEEDYGUN
