Newbie installing his own system
barry_mann
I am going to be installing my own system in my 2008 altima. i have boght everything but the sub box and wiring. I will be using the stock radio and i have a few questions.
1) can i have some out puts of the amp 2 ohm and some 4 ohm?
2) How do i make the sub 2 ohm with a single sub port
3) Is is ok to have more rms watts coming from the amp then the speaker is rated
4) do i need a compacitor
5) do i need the rca converters. from what i read it looks as if i can just wire rca cable directly to the factory stereo wiring.
6) what type of enclosure do i need. ( ported band pass sealed) and what size. I want to save as much trunk space as possible
7) what size speaker wires do i need
8) where is a good plce to mount the amp. i was thinking under the pasaaenger seat.
9) where can i get the color codes of the factory harness or where can i buy a reverse harness that is labeled
10) How would you wire this for the best sound.?
Here is what i have purchased.
For the front doors
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=52000&i=113KFC1682&search=Kenwood+VENDORID113&searchdisplay=Kenwood&tp=95
For the back dash
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=52300&i=113KFC698E&search=Kenwood+VENDORID113&searchdisplay=Kenwood&tp=91
1 - 12" sub
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=520&i=113W3011&search=Kenwood+VENDORID113&searchdisplay=Kenwood&tp=111
Amp Jackhammer 5 channel
http://www.mtx.com/caraudio/products/amplifiers/JH805_amp.cfm
u can but not a good idea
u wire the subs to 2 ohm has nothing to do with port
yes just keep the gains lower ( u mean more than rms speaker power i assume not max speaker power
no this is a band aid (search big 3 upgrade this will work better and buy a better battery
yes u will need either a loc, a rockford 360.1, cleansweep etc (last 2 will sound better but cost more ur factory stereo does nto have rca out
depends on speakers ur running and what is recommended sealed will be ur best bet in most applications
12 gauge- 14 gauge will do fine
if it will fit, and it does get very hot this is not the best location but will work
circuit city, best buy, ebay, etc
For the front doors
For the back dash
1 - 12" sub
hope this helps
response is under each question
oh yeah u can get a lot better equipment than what u got for the same or lil more hopefully u didnt buy that shit already
i payed $120 for all of the speakers and $150 for the amp brand new. I thought i got a pretty good deal. The local audio shop wanted $399 for the amp alone. I figured i would start out simple and then slowly upgrade. this is just a work car so i dont want to put alot into it. What equipment should i have gotten for this price. please enlighten me. If i can return all of this and get something better please enlighten me!
I was going to add a cpu fan since i read the 5 channel amps get hot really easy. I talked to MTX yesterday and they said it wouldnt be a problem, that these run cool but i figured just for safety sake. The main thing that concerns me is the watts are fine for the 6.5" speakers at 4 ohm's but the 6x9's need to be ran at 2 ohms and so does the sub. Would it hurt to run the 6.5" at 2 ohms or will they blow? My original plan was to run the 6.5" at 4 ohms and then the rest at 2 ohms but your answer 1 above changes that.
$120 including sub and 150 for the 5 channel amp all brand new
the only problem is, i am unsure if the kenwood warranty will hold considering the guy was going out of buisnuiss and i am unsure if he was an authorized dealer
line output converter it takes speaker output and turns it to rca out they are like 20 bucks at circuit city or best buy
they are a low budget option
best is cleansweep or rockford 360.1
the prob with using a loc to get ur rcas to amp is no manipulation of factory signal
most factory headunits cut bass at higher volumes so u dont damge their cheap paper speakers so the bass will sound real good with volume low and get weak when its up high
nvrmnd i was thinking u ordered from cruchfield //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
thats a good deal for a budget start up i would def upgrade tho
put a set of rsds 6.5 comps in front 87 shipped
and if u must have rear fill get 6x9 to 6.5 conversion plates and get a decent set for rear fill
so bridge the front 2 channel and bridge the back 2 channels. Now the sub is a 4 ohm to. what can i do about that or should i just live with it? Also couldnt i just bridge the 6x9's and leave the 6.5 as normal? Or would that be bad?
JH805 Amplifier Specifications
Primary Ratings
Power Output 37.5 Watts RMS x 4 Channels and 250 Watts RMS x 1 channel at 4 Ohms
Signal-to-noise Ratio (1 Watt) 75db (Front/Rear)
70db (Sub)
Secondary Ratings
Power Output 75 Watts RMS x 4 Channels and 500 Watts RMS x 1 channel at 2 Ohms
Power Output 150 Watts RMS x 2 Channels Bridged at 4 Ohms and 250 Watts RMS x 1 channel at 4 Ohms
Power Output 150 Watts RMS x 2 Channels Bridged at 4 Ohms and 500 Watts RMS x 1 channel at 2 Ohms
THD+N (Distortion) (1 Watt)
Frequency Response (-3dB) 20Hz to 20kHz
Maximum Input Signal 5v
Maximum Sensitivity 250mV
Dimensions 17-3/8" x 8" x 2-3/8"
Patented Pure N-Channel Technology
(Patent No: US05631608, US05783970)
Patented Adaptive Class D Technology
(Patent No: US06753729)
Patented Power Supply: (US05598325)
Crossover (Front) Variable High @40Hz-5000Hz, 12dB/Oct
Crossover (Rear) Variable Low @40Hz to 5000Hz, 12dB/Oct / High @40Hz to 8000Hz, 12dB/Oct
Crossover (Sub) Variable Low @40Hz to 200Hz, 24dB/Oct
Subsonic Filter 20Hz to 50Hz,12dB/Oct, Variable
Bass Boost +12dB @ 40Hz
What do you think would be the best way to wire this up.
now the amp has changed. I had a very bad dealing with stompaudio.com. Anyway i ended up purchasing a Infinity 5761a which is a 6 channel and i think it will work out better than what i had.
barry_mann
barry_mann
deer park
barry_mann
