Montana
Banned
Alright, so what I am running is two SA-12 D4s, and a Hifonics Brutus 1700
So, even though I got slapped in the face verbally for mentioning a power Cap on this forum, I have mine still hooked up.
View attachment 26536120View attachment 26536119
I have one 6Ga wiring running to my battery, to the positive Cap, then another 6ga running from the positive cap to the amp, then my 6Ga ground to the cap checked with meter its a 0.0 ground.
I'm almost positive that's right, my real question is if I have my subs wired correctly..
So, I have my SA-12 D4 wired in parallel. (one wire running from Positive to positive, then another wire running out of one of the positives to the termial and same exact thing on the negative)
They are 4OMH, so that cuts them down to 2ohm.. Right? And my Brutus 1700 should be pushing 1200 at 2OMH, but that is 2x the required power for that Sounddown... So, do I then need to run them in Series to get them back up to 4OMH? Brutus pushes 600 at 4omh.
Right now they are wired in parallel only, so that is pushing 1200 to each of them right? 1200 Per channel?
One last basic question, a "Class-D Mono" amp is basically a subwoofer amp right? Mono is it just sends one signal? instead of left right? What is the "Class-D"
Thank you for any educational tips you can provide!
Quick edit: Just to be clear, nothing is wrong with my system, it plays just fine. I am just double checking my wires to make sure I don't blow my new SA-12 D4s!
