So my posts trying to clear up the falsness in your tests are just "shit" to you? I guess ignorance is bliss. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
I'm not being difficult here; I'm trying to clear things up. You have NOT measured true RMS power and neither has anybody else who randomly tests like this. CEA does not measure power like this. They use purely resistive loads which almost completely eliminates the imaginary part of the power triangle. Have you bothered reading my posts, or xluben's posts (take note of the power triangle), and trying to understand them? Your results are NOT real results as you have a good amount of inductance as seen with the impedance rise. Anything over the DCR is rise in impedance which is caused by inductance. This makes the apparent power larger than the true power.
Let me mspaint it for you:
Notice how the black and red lines in triangle "A" are not very close to being the same size? Notice how the black and red lines in triangle "B" are much closer in length? This is the difference in apparent power (red line) and true power (black line). The blue line represents the reactive part of the load due to inductance.
If you want to make this test more accurate, use a purely resistive load and a scope to check for clipping. Then and only then will you have a pretty accurate test. If you can't do that, and keep it controlled, then try finding a frequency where the impedance rise is very minimal to reduce the variation in power.
I'm not trying to be a dick here, unlike you. I'm just trying to correct things and help you learn something. I'm sorry that you're upset I'm not praising you for these results. The only "real world" results you have given were the dB number difference from the 2500.1 and this amp.
Oh, and adding a capacitor in series will reduce impedance rise but I would not recommend doing it at all. It won't be worth the time or hassle and you would not see a gain from it, but it would work.
