*New Test: Sundown SAZ-1500D*
tommyk90
THE WHOLE THING!!!
Well, I got to test out a new Sundown SAZ-1500D today, something I've been looking forward to now for a couple days.
This test was done in my truck. Electrical system consists of 2 Everstart MAXX batteries, a 200 amp alternator, and 4 runs of 1/0 wire (2 positive, 2 negative).
Power results were as follows:
1 ohm, car off:
19.9 x 53.7: 1070 watts, rising to 2.7 ohms. Voltage was only dropping to 12.3!
1 ohm, car on:
20.7 x 54.3: 1090 watts, rising to 2.7 ohms.
In all, for the price this amp is a great buy. I would expect some great numbers out of this amp wired down to .5 ohm and have a little less rise than I experience in my truck. Even with less voltage this amp did a great amount of power. I only gained 20 watts going from 12.6v to 14.6v!
As for the scores, I used my single 15" type-r. Meter was placed in the passenger kick for this test.
Car off: 150.7 @ 44 hz
Car on: 150.9 @ 44 hz
To compare, the kicker zx2500 did a 154.0 @ 44 hz.
Once again, not nearly as much of a gain as the kicker or orion when I turned the car on. Efficiency played a huge role in that as well. The batteries would only dip to 12.2-12.3 while the orion or kicker had no problems dropping the batteries lower than that. Obviously the kicker and orion did more power, but for a $600 RETAIL amp, I'd say it holds its own very well. GREAT PRICE, especially for the power potential.
Overall, its a solid amp for the price and will be a very good daily driver amp for .5 ohm and 1 ohm loads. While I didn't get the power out of it that some others did, I feel that it did very well in my tests. A lot better than the 20.1 did versus the hype surrounding it. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
(and yes, I am fully aware of the board that is in the sundown and what amp it used to be in //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif)
The next test for this amp (if we have the time) is to test it on a 16v setup and possibly a lower ohm load. Hopefully that will happen in the next week or so.
are these the new hyped amps? stats look pretty good.
Yes it is, and yes they are. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Overall, i'm much more impressed with the sundown than I was with the 20.1, which is ironic for the people who know what I'm talking about. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Now thats a solid review, good job. and can i ask why it was ironic with th 20.1?
Well, i've been told by more than one person that the sundown is a close cousin to the 20.1 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
But i've been told the opposite by others. Maybe jake can come in here and clear this up for me. Would be a lot better than others spouting off stuff back and forth.
Test it at different frequencies to get the impedance rise down. Right now we're looking at a larger difference from apparent to actual power due to your impedance rise. You're going to see more variation because you're calculating power by using Vrms*Irms and that only gives you apparent power. With an impedance rise like that, you're putting a pretty large variation due to the imaginary load that is combined with the resistive load.
I'll be honest, I know NOTHING about impedance rise... but if Immacomputer is correct then I too would like to see actual power... my four Sundowns come tomorrow via UPS, I can't wait //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
tommyk90
THE WHOLE THING!!!
tommyk90
Chicago Heights, IL
Immacomputer
