new systems help even out the kinks
fcivc24
Head unit kenwood x889 Have
front : Infinty Reference 6.5 componets! Have
Rear : Type r 6x9s or rev series 6x9s Getting any sugestions
Amp : kenwood 8641 60x4 Have
Subs: Type r 10s or diamond d6 Getting any sugestions
Sub amp: MRD 1005 alpine Getting any sugestions
How do you think this would sound in a honda civic coupe? Any suggestions to any other brands would be helpful Thanks
if you are going for SQ i would go with the diamond audio 10's, as far as the amp, i have a directed 1100d, i would go with it or the 1500d, they are great amps and can be had cheaply. The rev series definitely gets my vote for the 6x9's
hope this helps a little
Zach
Zach
I have never heard this amp before. What does it put out? Is it effiecent?
Just depends on what you want. If you have the money for the alpine get it, Its class D so it will draw less current and it will help out your electrical system (I know I have a Orion 1200d, and it pulls a shit ton of current for the power it puts out. As for subs if you want SQ go for the diamond if you want SQL go for the Type R's. Rev Series 6x9s for the rears
Don't get he alpine amp or 6x9's. Get the rev's and look for a cheaper amp such as a directed, orion, jbl, kenwood, or even hifonics amp that will do the same job for much cheaper.
THE Alpine amp is only 330 new!! And i have heard good things about it. How is the Kenwood excelon amp? havent heard to many things on it?
Go with the Alpine amp if you can afford it, your elec. System will thank you, just make sure you buy dual 2 subs because that amp isnt rated to go down to 1 OHM. And the kenwood amp is a good one also
i have the rockford 800.2 4 ohm amp already and I want to upgrade the amp do you consider this an upgrade? my amp now is the a lil harsh on the elec system!
fcivc24
fcivc24
keys, fl / livermore CA
johnecon2001
BP1Fanatic
BP1Fanatic
