New System Plans
Dmeyer07
Sippitto
Hi everyone I'm looking to get some input on my current Stereo plans for a new system. I have an '07 Trailblazer that I'll be putting this in. My budget was ~$500 on 1 Sub, ~$500 on Mono Amp, ~$500 on a Head Unit.
Subwoofer NOT SURE?? LOOKING FOR A 12" DVC 1 OHM SUB TO MATCH AMP..
Amplifier: $299.99
Zapco ST-1500XM 1500W RMS @ 1-Ohm Mono D Amp
Headunit: $359.99
Pioneer AVH-X5600BHS 7" w/ (3) 4 Volt Outputs
Amp Wiring Kit: $59.99
KnuKonceptz Kolossus 4 Gauge OFC Amp kit w/ Rca’s, 120A fuse/Holder
How's it look? Any thing you'd change? Recommendation for a sub?
Thanks!
-Dave
First of all to match your amp you need a dvc 2 ohm sub to end up at a 1ohm load. Second once your at 1000rms 1/0 is what you should get for wiring. And third Have you got a budget for electrical? That's where people end up skimping out and it's one of the most crucial parts. You'll likely need an upgraded battery maybe a second one.
@Dmeyer07; If your electrical can handle atleast 1500Wrms, then I have a used 12" Fi Q I could sell you. Only a year old and still very good condition. Fully loaded all options including cooling, extra spiders, pf chamfers, low qts, internal lead, Ice blue dustcap... It is dual 2 ohm so you can wire it to a 1 ohm load. Asking for 200 + shipping. PM me if you're interested..
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
214
624
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
16
Dmeyer07
Sippitto
Dmeyer07
The Woods
blazian87
maylar
    Jun 2, 2024
    Jun 1, 2024
