First time posting here. So far I have just bought a pair of speakers from the classifieds section in this form.
I would just like to know if all the components of my new system will all work nicely with each other. It’s a little late to be asking as I have bought them all though I haven't installed anything but the deck. BTW this is going into a pontiac fiero, a small two seater, so I don't have much room.
So here it is:
Infinity Reference 4" x 6" two-way plate - Rear
RMS-45w
Peak-135w
Impedance-2ohms
http://www.infinitysystems.com/car/products/product_detail.aspx?prod=REF6422CFP&cat=REF&ser=REF&Language=ENG&Country=CA&Region=USA
MB Quart Discus 5.25 Component - Front
Power Handling: 35 - 90w
Impedance- 4ohms
http://www.mbquart.com/en/produkte/car/discus/produkt.php?nr=dsg_213
Pioneer DEH-P780MP
http://www.pioneerelectronics.ca/POCEN/Products/Car+Audio+Video/Source/CD+Receivers/DEH-P780MP
Tang Band 5.25 Subwoofer
RMS-40w
Peak-80w
Impedance-4ohms
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=264-831
This sub is to be used in the stock sub box that came as a factory upgrade.
I don't need any amp for the speakers, this system is just to replace the 20yr old factory setup. I may add one later if I get more money to put into this system.
I do need an amp however for my sub. It's a very small sub, as you can see, at 80w peak. So I have been looking for a cheap amp. So far I have found these 2 close to me:
Alpine 3517
specs:
-30W x 2 into 4 ohms from 20 Hz - 20 KHz at 0.04% THD
-35W x 2 into 2 ohms from 20 Hz - 20 KHz at 0.08% THD
( I would bridge them if I can, not sure if I can bridge them, Can I?)
Pioneer GM-X302
(couldn't find any info for myself, this is sellers info)
35w x2 stereo
80w bridged
I like the Alpine out of the two because of its small footprint, I couldn't find the dimensions of the Pionner. I want to put it under my seat. That’s why I would like a small size. Is one of these better then the other? I’ll probably get both anyway, they are really cheap.
The one thing that has me worried is the 2ohm infinity speakers. It says its fine to connect to a 4ohm deck on the infinity website. But it says not to connect anything other then 4ohm or 8ohm speakers to the deck in the manual.
Will it be ok??
Thanks in advance for your help //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
So here it is:
RMS-45w
Peak-135w
Impedance-2ohms
Impedance- 4ohms
Pioneer DEH-P780MP
RMS-40w
Peak-80w
Impedance-4ohms
Alpine 3517
specs:
Pioneer GM-X302
35w x2 stereo
80w bridged
Will it be ok??
