New some Advice
you know this how? probably not by your 11 posts and your whole month spent on the forum.
//content.invisioncic.com/y282845/emoticons/blackeye.gif.66a1670f5aaf7f406e783a63e3387dc5.gif//content.invisioncic.com/y282845/emoticons/slap.gif.87520e8ca8e90076ac30e777c0de5331.gif//content.invisioncic.com/y282845/emoticons/noevil.gif.0723d47b61c306c6d554fb6555014096.gif
Any 1000+ watt Amp that is 2Channel will work??
since you can wire these two dual 4 ohm subs down to a 1 ohm load(wire the coils in parallel and the subs in parallel), you can get alot out of a big mono (one channel) amp which puts out around 1000 watts @ 1ohm...if you use a two channel amp, each channel will be seeing a 2 ohm load, so look at the specs and figure out how much each channel of the two channel amp will be putting out @ 2 ohm
SticBandt2004
The Illest...
SticBandt2004
Grand Rapids, Mi
jaygeorge1979
