new problem
jasonlee
ok i got everyhing hooked up subs and amp. AMP WILL NOT POWER IN CD MODE OR AUX MODE ONLY IN THE TUNER.I dont know what i did wrong. i think it might have to do with the blue turn on wire maybe maybe i spliced into the wrong wire on the head unit. someone help me please!
1st guess is going to be you hooked the remote turn-on lead to the power antenna activation output on the head unit instead of the remote accessory activation.
If there is another blue wire in the head unit's harness then swap to that and see if it cures the problem. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
If my guess is correct you have your amp's remote lead connected to the one without the white stripe and if my assumption is correct then you need to swap it to the wire that does have a white stripe down the side of the wire's insulation. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
That should cure your problem. If my suppositions are accurate what you've done is connect that remote lead to the power antenna output which only carries current when the receiver is in tuner mode. In CD or AUX mode it carries no juice and consequently will not turn on your amp in those function modes. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
jasonlee
jasonlee
yorktown va
Prowler573
Mike Mccabe
