New member wanting to learn new things
David1
CarAudio.com Newbie
Fl
Hey guys i need to pick yalls brains about a few things if its ok. Ive been buying my audio equipment for about a year now and im almost done buying and about to start installing. I dont want this to be a mile long but ill list what i have to better help with the questions i have. 2 sundown sld 12" subs, 4 rockford fosgate t1650's, 2 rockford p132's, JL audio 1000/1 w/ rbc-1, jl 400/4, kenwood excelon ddx9905s headunit, stinger 8k series rca cables, sky high 1/0 power & ground, 1/0 big 3, Jim M battery terminals, still ahve to buy sound deadning pieces for doors.
1st question is the jl 1000/1 enough to push the sld's? If not i have a precision power black ice 5000.1 .5ohm stable
2nd is do i need a crossover or is the kenwood ddx9905s enough? It has a Ton of options.
3rd the t1650 are 4ohm the 400/4 is 2ohm stable, so any reason i cant or shouldnt just wire them together at the amp?
4th should i do a big 4 instead of big 3? Ive heard yes
5th can i use a distrobution block for both grounds or do they need to be individual?
Thank you for any help or recommendations you can give
Some reference pages:
Assuming you have the 2ohm dvc versions and not the 4ohm dvc versions, yes. Ideally the amp would be equal or slightly higher power than the subwoofers but 1000 is 83% of 1200 which is close enough to sound good. Some subwoofers don't like to be under-powered but that's a minor difference that shouldn't matter. I would leave the PPI out of it. I don't trust their quality very much and their ratings are always exaggerated. I guess if you have to run 4ohms then that might reluctantly be your best option, even then I might use the JL or get a different amp.
I would see how it sounds before going the EQ or crossover route. I feel like it's good to be familiar with the sound and the limitations of your HU before you introduce them anyways. I usually build and buy my systems in chunks which helps me know how much the new stuff is actually helping or if I'll actually need it.
The t1650 are 75W rms @ 4 ohms, so wiring them together in parallel would give each 50w RMS per channel. If you intended to bridge the channels and wire them parallel that would be a 1 ohm load on each channel so that's not good. If you bridge them and run series you're getting less power as well. Just stick with one per channel, it's perfectly matched 75w RMS and 75w RMS so there's no reason to complicate the wiring.
I've never seen any testing on the merits of the 4th, so not gonna waste your time pretending I know the results. Your system sounds pretty small though, I'd say it could go either way as to even needing the big 3 but it of course never hurts.
You can and probably should use a dist block for multiple grounds.
Good idea on sound deadening, that's usually the first thing I mention before upgrading full range door speakers to get the most out of them and not be disappointed by the difference. It seems you've done a lot of research relative to how much most people start with.
I didn't notice, oh well, it's not the worst section mix-up considering its their first post.
I dated a chick once, way back in mayonaisse, that had a saying. "Fuc k em and feed em red hot dogs". First off, what? Second I kinda like them red hot dogs. Liked her too, firey redhead., named Stephaney. I should look her up.
David1
CarAudio.com Newbie
David1
Fl
Slo_Ride
