New install - not what I wanted. Advice please
BrandonYates
So I just installed my first Amp and sub in the trunk of my 2004 sebring convertible. The amp and sub are rated at 300W 4 ohms
I installed this amp:
http://www.crutchfield.com/App/Product/Item/Main.aspx?o=m&g=120&i=500MRPM500&tp=115
and this sub:
http://www.crutchfield.com/App/Product/Item/Main.aspx?showAll=N&g=510&i=158XSLB12&tp=112
They are installed in my trunk. It sounds decent when the trunk is open, but as soon as I close the trunk I can barelry hear the sub at all, even with the gain turned all the way up, music loud, etc. Is the problem with the equipment I am using, or does my car just have a soundproof trunk?
I am either going to figure out a wa to mount the sub inside the car, or I am gonig to return the sub and try to find a dual coil sub so I can take advantage of the full power from my amp (rated 500W at 2 Ohms, only 300 at 4 ohms.)
What should I do?
I would say the biggest issue is the fact that you have a convertible. The "pocket" that your top drops into will block a lot of the sound coming into the cabin area.
was gona say that, theres metal bracing to stiffen the chassis behind the seat thats blocking the sound.
BrandonYates
BrandonYates
Philly
shpatb
