2005 Chevrolet Impala
Headunit: Alpine CDA-9830
-3-4v preouts
Four Channel Amp: Alpine MRV-F345
-75 watts RMS x 4 at 4 ohms (150 watts RMS x 4 at 2 ohms)
Sub Amp: Alpine MRD-M301
-150 watts RMS x 1 at 4 ohms (250 watts RMS x 1 at 2 ohms)
XM Tuner: Alpine TUA-T020XM
Auxillary Input: Alpine KCA-121B (used to feed XM tuner above and also Carputer via 1/8” to RCA Adapter)
Carputer:
Xenarc 700 TSV: 7" VGA Touchscreen Monitor
Rikaline 6010 USB GPS
Morex 2699B Case
Via Epia MII 1000 Motherboard
512MB Ram
80 GB 2.5" HD
Slim DVD/CDRW
Turtle Beach Cataline Soundcard
ITPS
IGuidance 2.0 Navigation Software
OBDII Diagnostics BR-1 Interface (Engine Diagnostics)
Netgear 802.11g Wireless Card
External Seagate 250GB Harddrive in USB 2.0 Enclosure
Opus 150 Watt DC-DC Computer Power Supply
Subwoofer: (2) JL Audio 10W2V2 –dual 4 ohm version
Front Speakers: Infinity Kappa 60.7CS
-2-90 watts RMS (270 watts peak power)
-2 ohm impedance
Rear Speakers: Infinity Kappa 693.7i
-2-110 watts RMS (330 watts peak power)
-2 ohm impedance
Battery:Yellowtop Optima Upgraded Battery (already installed)
Sound Deadening: 150 sq. feet B-Quiet Ultimate
Power Wiring: Knuconeptz 4 Gauge Amp Wiring Kit
-20 Feet 4 AWG Blue Kolossus Power Wire
-3 Feet 4 AWG Silver Kolossus Ground Wire
-One FH-24 with 80A Fuse size
-TWO 5 Meter Klarity Kable Blue OFC RCA Cable with Built in Turn On lead
-20 Feet BLUE Klear Kable OFC 12 Gauge Speaker Wire
-2 Gold Plated 4 AWG Ring Terminals, 2 Gold Plated 4 AWG Spade Terminals
-6 feet Split Loom and wire ties
Distro Block: Knuconceptz 4 Output Fused Distro Block
-4 gauge input & 4 8 gauge outputs
Ground Block: Knuconceptz Ground Block
Speaker Wiring: Knuconceptz 12 Gauge Speaker Wire
Battery Terminal(s): Stinger SXBTM
Current Issues/Questions:
1. How do I determine what size fuses I will need? I need one at the battery and then three at the distro block; one for each amp and the Carputer.
2. How do I extend my headunit wire harness? (I am relocating headunit to approx. 2 feet away from stock location)
3. How do I extend my stock antenna, keeping in mind it is a GM vehicle
4. Can anyone recommend a replacement XM antenna for the Alpine TUA-T020XM unit?
5. Should I replace the stock speaker wiring with the upgraded wire and run it directly from each speaker to the four channel amp in the trunk?
6. How hard is it to wire up molex connectors for the touchscreen AND powered USB hub up front (touchscreen is 12v and hub accepts 5v and the carputer power supply has inputs for this, I just need to build a cable with molex connectors on each end). I also need to prepare another 12v molex connector for the external harddrive which will also run off the power supply.
7. Is the sub amp two small for the two 10” JL subs?
8. Do you think the Infinity Kappa speakers will be sufficiently powered by the Alpine 4 channel amp?
9. Do you have any recommendations for a trunk layout. At first I was thinking a fiberglass enclosure for each of the amps in the wheel wells, but practically speaking, I have never fiberglassed before. I read the sticky regarding fiberglassing and it definitely motivated me.
Any other recommendations/comments are greatly appreciated. All of these items have already been purchased and a local installer has fabricated a console to house the Alpine radio and USB hub which has not yet been completed. The same installer was supposed to do the installation, however that seems to have fallen through and I am looking for another local installer in Florida. I would also like to point out that this is my most involved install thus far and I am a little overwhelmed at this point.
-3-4v preouts
Carputer:
Morex 2699B Case
512MB Ram
80 GB 2.5" HD
Slim DVD/CDRW
ITPS
-2 ohm impedance
-2 ohm impedance
