cut out
fatboy
nc
so i start listen to my stero with the sub on and all of a sudden my sub cuts i dont mess with it for a couple of days and it starts working and then again it cut out so i have no clue what to do any suggestions?
thx
A little more info. would be great.
What amp are you using?
What size power and ground cable are you using?
What sub, subs are you using?
I would venture to guess though that you have a loose cable. It could be a speaker connection, or one of the power cables, an RCA, or the remote turn-on cable. Does the amp go into protection mode, or just not come on at all.
Yeah that is what I would bet on, a loose cable, check all of them. One of them is probably a little loose and when you turn or hit a bump, it shakes a little loose. Just give your whole system a quick look over and see if you notice anything.
fatboy
fatboy
nc
amr952
