Andy Somnifac
Hey everyone,
I have recently installed an Eclipse AVN2210P Mk II in my 2000 Toyota MR2 Spyder. So far I love the unit. I only have big issue at the moment, and it's not even that big of an issue. I get interference when stepping on the brake pedal or using turn signals.
The setup is as follows:
* AVN2210P MkII HU
* MTX Blue Thunder PRO4X75 Amp
* Infinity Reference 6022i 6 1/2" Speakers in the doors
* Rockford Fosgate Punch P1694C 6x9" Speakers in the rear
I've done the following to try and trace the source:
* Checked to see if the interference is noticeable when running off the HU's amp. It is not.
* Plugged an iPod into the amp's input to see if the noise is noticeable. It is not.
And a rundown of other items that may or may not be relevant:
* I've taken the ground off the vehicle's harness and firmly grounded it closer to the HU.
* The ground on the amp is approximately 12" long, and grounded right below where the amp is mounted in the rear cubby.
* The signal leads between the HU and the amp are beefy RCAs, run under the door sill on the right side of the car.
* The level of the interference decreases as I turn down the gain on the amp. I can get it to the point it's barely noticeable, but I'd like to eliminate it so I can turn the gain back up a little bit.
* The interference sounds like a quick pop when I depress the brake pedal, and the same when I release it.
It has been suggested that I take the power lead to the HU and run it straight back to the battery, because a couple theorize it could be some kind of voltage drop that's causing the interference. Anyone have any thoughts on this theory, or any other thoughts and suggestions as to things to check?
Thanks.
* AVN2210P MkII HU
Thanks.
