soldiermedic
Noob4Life
If any of you use WinISD for the initial part of a box build, I need some advice on where to go from there. I also have bass box pro, but things are a bit off as I am still learning it. If any of you can help, I can send the files I believe. If not, the initial look is a 1.75 cu box tuned to 22hz with an 80.3x12x2 inch port, not including displacement. Sub is a Dayton HF 12
