new and need your guys in put
Hello all. just need to know what you guys might think of this set up. its all going in behind the 3rd row seat of a 99 dodge durango.
amp. sound stream rubicon 1.2500
sub- american bass hd 15 dont know if it is a d1 or d2
box- 3 cuft 1/2 face slot port to 37hz
wire- 0ga 1 run on stock system
I have tried to find a set up like this but seems not to many people like to run a one sub set up but one guy with it in a buick that looks the sub is going to fall out of the box.
need more info dont bash on me just ask lol
Well for a noob you pretty much got it all figured out haha seems like a good deal to me. I prefer single sub setups cause I think it's more impressive to run a single beefy sub than a couple mediocre ones. Only advice I would give you is keep the amp low on that HD cause the suspension needs some time to loosen up. Haven't used one of those subs though 3 cubes seems a bit small, it may prefer 3.5 if you can fit it.
If the sub is D2 you can wire it to 4 ohms to start off, that should be around 1000w I think and 4 ohms is pretty efficient. Once you get your ish in rewire down to 1 ohm and turn up the gain to around 2000-2500
jgaudio69
jgaudio69
little falls ny
Papermaker85
