New, and Looking to upgrade
Hello,
Just joined and was looking to buy new subwoofer/amp for my car.
I have these already picked out and I was wondering if these will work or if anyone can suggest anything better.
Subs -
2 Pack of Kicker CVR124 (07CVR124)
Two 12" Dual 4 Ohm CompVR Series Subwoofers
Power Handling:
Peak: 1600 watts per pair / 800 watts each
RMS: 800 watts per pair / 400 watts each
Impedance: Dual 4 ohms
Inverted Structural Dome Polymineral Injection Molded Cone: Remains rigid, and lowers distortion
Rear Cone Brace: Offers unmatched strength and resistance to deformation
Ribbed Santoprene Surround for Linear Cone Motion
Silver-Coated Stamped Steel Basket
Stitched Surround: Ensures the cone and surround won't separate, even under the highest loads
High-temp Polyimide Film Voice Coil Former
Dual Ultra-Length Voice Coils
Perimeter Venting
Sleeved High-Power Tinsel Lead Wires
Spring Loaded Nickel-Plated Terminals
Other search terms: CVR12 4 ohms, CVR124, 07CVR12, 07CVR124, 07CVR 12" 4 ohm, CompVR 12", CVR 12", Comp VR 12"
Amp -
Kenwood KAC-9105D
Performance Series Class D Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 500 watts x 1 chan.
2 ohms: 900 watts x 1 chan.
1 ohm: >900 watts x 1 chan.
Max power output: 1800 watts x 1 chan.
Digital amplifier technology
Dual mono driver ready
MOSFET power supply
LED power indicator
Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
Stackable operation capable
Phase inverter (0°,180°)
Speaker-level inputs with signal sensing for automatic turn-on
Preamp RCA outputs
Line output terminals for extension
Short circuit, DC offset, overload, and thermal protection circuitry
Aluminum die cast heat sink
Built-in cooling fan
Gold-plated RCA level inputs
Gold-plated screw terminals
Variable low-pass filter (50-200 Hz, 24 dB/octave)
Single side exposure terminals for multi-installation
CEA-2006 compliant amplifier
Frequency response: 5-200 Hz
Dimensions: 13-3/4"L x 2-5/16"H x 9-3/8"D
4-gauge power and ground leads recommended.
1-year Sonic Electronix warranty
Box-
Absolute DAG 12
General Features:
12" Universal Dual Ported Enclosure
Two tweeters pre-installed in enclosure
Terminals pre-wired for easier installation
Two sets of spring binding clips
Dual ported design
Made with 3/4" MDF construction
Two side handles for movable convenience
Covered with durable black carpet
Pre-lined Polyfil enhances air space for better bass
Subwoofer mounting depth: 9"
Subwoofer cutout diameter: 11"
Box volume: 1.39 cubic feet (per chamber)
Total box volume: 2.78 cubic feet
Dimensions: 10-1/4"TD x 15"BD x 36"W x 14"H
Port Specifications:
Round ported design
Number of ports: 2
Port volume: 0.0036 cubic feet (per port)
Total port volume: 0.0073 cubic feet
Port dimensions: 2"Diameter x 2"Depth
Not necessarily the prices and websites I was going to buy from but just to check if the equipment specs make sense.
Also wondering if its better to have professionally installed vs someone like myself who is noob at installing.
Any ideas?
First question, do you want to listen to someone who knows what they're talking about or just listen to yourself and ignore the adivce? Is this just gonna be for beatn' around the block and not competeing?
There's better out there for a cheap setup. Someone show this guy something good in the classifieds. I would but i'm at work, on da cell...
Yep. Without the budget there's not much we can recommend.
---------- Post added at 02:24 PM ---------- Previous post was at 02:23 PM ----------
1000 bucks is a pretty decent budget if you've already got the head unit. Let's see what I can figure out.
rangertjsc
rangertjsc
Barnstable, MA
AlterEgo99
Mike Mccabe
