New amp, subs barely move
RDSHunter
Just installed my new Cadence TXA1000D monoblock amp to my two JL 12w3v3s. Went from pushing 500 rms x1 @ 4 ohm to 1000 rms x1 @ 1 ohm. I was expecting to see my subs move a lot more than they did but the opposite is true. I know the wiring is right and have played with the gains and my HU settings but they still wont move like I know they should. Any suggestions?
The subs worked fine with my amp that i took out minutes before putting the new one in. I have the wiring set up like so:
L sub + -> R sub + -> Amp +
L sub - -> R sub - -> Amp -
Tried wiring both pos to the amp and both neg to the Amp as well.
I also tried playing with all of the filter settings and saw no dofference as i moved them
You have single 4 ohms voice coils, so both together your only seeing 2 ohm. That's the reason for your lack of power. You aren't seeing as much power with your new amp because it's not meant to put out max power at 2 ohm. I hope this helps Bro!
The subs are both 2 ohm SVC subs, each meant to run at 500 rms. The new amp puts 1000 rms @ 1ohm, 650 rms @ 2ohm and 350 rms @ 4 ohm
RDSHunter
RDSHunter
Detroit, MI
LosIsATool
