New amp install questions
  • 4
Jwilk
Hey guys, first post so excuse me if im doing something wrong.
So i have a 2 channel 400W amp thats 2ohm stable, i also have 4, 4ohm 100W door speakers. Basically i want to know if i can run two in parallel on each channel and not blow up the amp? Also, if each channel is theoretically putting out 200W each does that mean the two 100W speakers on each channel would run at “full” power if wired in parallel? Thanks.
Which amp are you running ?
yes 2 speakers per channel is 2 ohm stereo and will be fine u just won't have a fader.. i had 2 systems like that in 2 cars for 8 years.. as always set gain properly (not all the way up) and hp xover around 80-100hz to protect speakers from distortion..
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Sounds like your front stage is overpowering your sub stage/ Weak sub stage. Is this a 4dr. Sedan or a Hatchback WRX? Where do you have the sub...
22
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
Rockford Fosgate R2-750X5 I just bought a audiocontrol converter and hopefully that will help
954
Jwilk
Jwilk
Wisconsin
BOOMINGRANDPA
    May 12, 2024
Brendon Jenness
    May 11, 2024
