New amp install questions
Jwilk
Hey guys, first post so excuse me if im doing something wrong.
So i have a 2 channel 400W amp thats 2ohm stable, i also have 4, 4ohm 100W door speakers. Basically i want to know if i can run two in parallel on each channel and not blow up the amp? Also, if each channel is theoretically putting out 200W each does that mean the two 100W speakers on each channel would run at “full” power if wired in parallel? Thanks.
Which amp are you running ?
yes 2 speakers per channel is 2 ohm stereo and will be fine u just won't have a fader.. i had 2 systems like that in 2 cars for 8 years.. as always set gain properly (not all the way up) and hp xover around 80-100hz to protect speakers from distortion..
Jwilk
Jwilk
Wisconsin
BOOMINGRANDPA
