New Aftermarket Deck Installation - Now Engine Won't Shutoff Until Door Opened
  • 2
tommy234
I recently installed a new deck in my GF's 2011 Chevy Aveo5 and now the car seems to be unable to shut off when the key is pulled. It will continue to run until one of the door's is opened.
I'm not aware of anything a deck install would do that would cause this it may just be a coincidence.
Any Thoughts???
wow thats a new one for me.. did u connect any wire to any part of the ignition wires? because my hu won't cut off until i open door but if car don't cut off sounds like u got wires mixed up somewhere..
I had to run a separate power wire to a switched fuse(I chose the wiper fuse). It was included in the harness and i spliced all those wires according to the documentation.
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
659
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
765
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
16
tommy234
tommy234
Ontario
tommy234
    May 18, 2024
    May 18, 2024
