neeed help with 0/4 gauge
the amp can be briged out to run 1000 watts to each sub and i hooked up my other and and it lite my 8 gauge on fire at the amp cause it wanted to much power
yeah i no but we can bridge it out to two subs but i gotta find a way to run it saftly in the back of the car
you can bridge a 2 or 4 or 5 channel amp... you can not bridge 1 channel...
you can have 2-3-4-9-10 subs running off of 1 single channel if you want... but you can not bridge 1 channel to nothing...
Yeah it doesn't work that way. Your amp is internally wiring the two inputs together. Your subs will be sharing the 1000 watts, so about 500RMS each is what they'll see.
For wire, 4g would be fine. If you plan on upgrading or adding a 600+ RMS 4-channel, I'd go with 1/0.
solo-x
boom
solo-x
chattanooga
chunky cumz
