Needing some feed back on my build I'm planing
tposton103
US
Okay I'm starting to buy some parts for my build. Buying a zv4 12 2ohm tomorrow and there's a few things I'm undecided on. I'll give yall a quick rundown of the plan but I'm open to changes. Zv4, CT 1400.1, 4 sundown 5 1/4, 4 sundown 8" mid range, sundown 4 channel 400 watt, second skin dedenor, XS power battery under the hood, SHCA Big 3 and 0 or 1/0 gauge wiring kit and 8 Guage kit for speaker amp. The things I'm completely undecided on are my alternator, box (ported or 4th order), and head unit (den and a half flip down or double den?) I'd like to get as much feed back as I could with this so I can build my perfect system. I would like to be able to do some sort of hair trick but I don't need it to be extremely loud just loud enough. No competitions just going to do a clean daily build. Like I said though I'm open to all suggestions except on the speakers (been a sundown fan boy for a while lol).
Sent from my SAMSUNG-SM-G891A using Tapatalk
Not working with the best budget either so try to think budget friendly Ish. Not trying to break the bank but don't mind spending money where it's needed. I'm only 18.
I wouldn't touch ct sounds screw that scammer... Look into ampere audio or twisted sounds for amps. YES F U coleman u P.OS.also with alts Singer and ohio gen r the ones i trust. EA and mechman and dc took forever to vet a answer from and Singers cs is top notch
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
820
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
You got plenty of space 30"h x 40.5"w x 65"d even triple baffled, double walled with bracing. What vehicle is this going in may I ask?
16
928
tposton103
tposton103
US
Hertz Mafia
    May 16, 2024
    May 16, 2024
