needing box plans... any good box design programs
  • 1
rockmo
i want to design a box for my truck, with 4 12's. i am needing a program or some help on getting it ported right, and getting the volume correct.
4 12's, they need 2 c. ft, and i am still not sure what to tune it too. the book that came with them says 2 cubes at 40 hz. but i will use as a daily driver and local comps. and i have been told 30 to 35 hz! so i have found some single 12 boxes that are at 34 hz. what do i need to shoot for to get some decent spl numbers?
truck is a 91 chevy ext cab, and the max measurements are 62 inches wide, 18 inches tall, and 23 inches deep. this will put the top of the box about 2 inches behind the seat. and about an 1 or a lil more away from the sides, and right against the back wall. and i will raise the box a little so the subs can be facing down. so it can be a lil shorter then 18 inches, like 16 would be good. tryin to keep it below the windows on the side.
i want the subs facing down, should the ports be down also? i have been told that subs down and ports down will give good bass in the seats.
also want it slot ported no round tubes, i have access to all the tools needed to build one! any help or suggestions would be greatly appreciated. layouts or drawing welcomed.
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
927
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
You got plenty of space 30"h x 40.5"w x 65"d even triple baffled, double walled with bracing. What vehicle is this going in may I ask?
710
rockmo
rockmo
halfway, mo.
rockmo
Decebal
    Jun 10, 2024
