Hey guys. I just wired my friend's sub amp, but I have a slight problem with the power. The power LED doesn't stay on constantly, but it will flash whenever the bass hits hard on a song. Everything seems fine but the remote wire. I tested the voltage on the power wire and it was +12V, but the remote wire only has 6V. I know it's the current that turns on the amp, but if not enough voltage, then not enough current, correct? So, I guess I need to find another switched power source that I can hook the remote wire to because it's pretty much impossible to get back behind the head unit again. In the mean time, could I just run a jumper wire from power input on the amp to the remote input just to see if I can get 12V? Or will that provide too much current? His car is a GM Jimmy ('98 I think) and I'm now thinking about running the remote wire to a switched 12V source in the fuse box. Is there an easier source that I can use?
