Roman G
I got a pioneer 10"sub model TS-W29C, Wired to an Eclipse EA-3422 bridged. I am just wondering if it underpowered. It seems that anything I do it still sounds like ***. Now I know it's not the best, it's just what I have for now. Plans to upgrade to a new amp and sub as funds allow. Specs for the Eclipse below as well as a pic of the sub and box.
Thanks
Subwoofer Features:
* IMPP Composite Cone Woofer
* Dual-Layer Urethane Surround
* High-Energy Strontium Magnet
* 4-Layer, Long Voice Coil
* Aluminum Voice Coil Bobbin
* Conex Damper with Damper Ring
* Projected Pole Yoke with Vented Pole
Specifications
* 450 Watts Max. Music Power
* 120 Watts Nominal Power Handling
* Sensitivity: 90dB (1W/1m)
* Frequency Response: 20 - 4.5kHz
* 4ohm Rated
* Recommended Enclosure: 1.0 Cubic Feet
Eclipse EA-3422
4/3/2 Channel Power Amplifier with Channel Flex Crossover plus Subsonic Filter
Features
* 123W × 4 Channel Max. Power Output at 2 Stereo
* 70W × 4 Channel 0.1% THD at 2 Stereo @13.8V (RMS Continuous Power)
* 50W × 4 Channel 0.1% THD at 4 Stereo @13.8V (RMS Continuous Power)
* ChannelFlex Crossover
* Adjustable High-Pass Frequency (50–200Hz, L/R Independent)
* Low-Pass Frequency (90Hz)
* Adjustable Bass-Boost Level (45Hz, 0–9dB, F/R Separate)
* High-Current, High-Speed Output Devices
* Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
* Epoxy Composite PCB
* 2 Stable Design
I also forgot to mention that, that is not my current wiring. I have since ripped out the interior and did it right.
Thanks
Subwoofer Features:
Specifications
* 4ohm Rated
Eclipse EA-3422
Features
* 2 Stable Design
