need to fix my dads mistake
i wish i could deaden my doors right now but i seriously can't, my dad has been on my case bout me spending money on my other project, so right now i only afford to change out the speakers (something he wont notice), its a mod that he will not notice so he wont know, theres no way i could deaden the doors without him finding out
hell my budget it prolly to high neways
ok good front or rear speaker setup for under 300 there thats my choice, plz advise (yes i change my mind alot)
FRONT!!!! -- and what do you expect to do with the tweeter so he won't find out you installed a component set lol... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Put it behind the grill? eew... I guess you could -- assuming you have the clearence...
Are you going to run these new speakers off head unit power? If you are I wouldn't suggest you drop $400 on speakers. I would use about $200 of that budget for front comps, $50 for rear fill coaxials, $100 on an amp, and about $50 on deadening.
id nab a set of these http://www.infinitecaraudio.com/cgi-bin/icastore.cgi?user_action=detail&catalogno=SSX615 put them in your door get some sound deadener deaden the door and get an amp http://www.infinitecaraudio.com/cgi-bin/icastore.cgi?user_action=detail&catalogno=THUNDER3202 and be done with it until up grade time for the subs. want to make it better when you up grade? put them in kicks and add sub/subs and another amp for them. (memphis syncs would be cool here too but are more $$)
wow lots of input now
yeah after playing with my settings i can see how new fronts would help, i found more bass already...now if only i had known bout that before i started my mission to blow these things
i've seen these things online, that a lil foam pockets u put behind the magnet that has a lip that sits behind the rim the speaker and the mounting plate, are those any good? would it help even the slightest? could i jsut deaden the area around the speakers and wait till later to do the whole door?
if i got the comps....would i NEED to hook up the tweeter? i mean my rear speakers are literally right behind my head so i can hear them fine, i jsut want some more bass for now, i could hook the tweets up in a few months
thats why i suggested what i did. when you listen (and i do mean really listen to something) do you turn your back to it? our ears take in side/forward sound much better than they do from behind (unless you are a freak of nature with wolf ears that point in 270 degrees or sumthin)
my rears speakers aren't mounted perfectly vertical, they are 'aimed' towards the front of the car and its a hatchback
so wouldn't to the sound travel to the forward area more?
But it is still coming from the rear...//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Well it is a longer path length and there would be all kinds of destructive interference that you brain will see as spacial ques and muck up the sound stage :p -- you can correct for this with time alignment but all the passengers are still quite screwed :p -- not to mention there are localization ques that will make it obvious that the music is coming from behind... and it won't seem like it is coming from in front of you like a virtual 'stage'
sanmarcosZfreak
AE Installer
sanmarcosZfreak
Kissimmee FL
sanmarcosZfreak
BP1Fanatic
BP1Fanatic
