need tips on first box build
Don't use sealant, use wood glue to hold everything together. And predrill your screw holes first. THat way the mdf won't split. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I normally cut everything, lay it out to make sure it fits, then glue a panel up, clamp it. Then predrill the holes and screw it together. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
pre drill and counter sink your holes. nothing looks worse than having a big a$$ piece of wood sticking out the side from were you split it at. mark everything out and prefit before you drill anything. it will save you head aches in the long run.
this is what i do. first make sure everything will fit before i do anything.next get 2 peices vertically to support a side or back,lying flat. then put wood glue on the 2 peices. place the peice of wood on the glue and adjust it a little till perfect. let it sit and not move for like a min of 2. drill the 4 corners install 4 screws. and put one in the middle.then u will be able to find out the rest
ok so i should just go ahead and glue the pieces together first (like bottom/side , top/side , port/bottom... ect... ect...) and then once there dry and already held together then i go ahead and predrill , then drill the screws... should i use the same width of screw when predrilling + go as deep as the screw is , or should i make it a bit skinnier + not as long so the screw has something to hold on to?
sorry for noobish ?'s but im not one for shop class //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
no, you need to screw it together while the glue is wet. this is what makes your glue bond strong. It also helps pull the baffles tighter together while the glue is wet/drying to make a better seal.
Twistid
Twistid
in a space out of sound
j3bus2k3
